yoid Posted August 10, 2006 Share Posted August 10, 2006 I have enabled DHT , but it doesn't work (it is not green) .Firewall is enabled for bitcomet (permit all in NIS) . How make it working?I don't understand , i have never had this before. thanks Link to comment Share on other sites More sharing options...
kluelos Posted August 10, 2006 Share Posted August 10, 2006 The DHT network uses UDP packets, so your firewall rule must be set up to permit UDP as well as TCP. Some firewalls allow you to specify "both". If yours does not, you'll need two separate rules, one for TCP, one for UDP. You do not need DHT in order to download. It's nice to have, but by no means necessary, and many torrents have it disabled anyway. Link to comment Share on other sites More sharing options...
