dmw Posted August 10, 2006 Share Posted August 10, 2006 Greetings, My DHT is showing not connected. I have clicked the enable tab in the preference area, but no change. Is there something blocking the connection on my computer? Maybe a spybot filter or something. Any suggestions are welcome. Thank you, DMW Link to comment Share on other sites More sharing options...
Dark_Shroud Posted August 10, 2006 Share Posted August 10, 2006 Spybot wouldn't block this, but your firewall will. BitComet needs to allowed TCP & UDP access on the port you have it set for. Link to comment Share on other sites More sharing options...
dmw Posted August 10, 2006 Author Share Posted August 10, 2006 Greetings, My DHT is showing not connected. I have clicked the enable tab in the preference area, but no change. Is there something blocking the connection on my computer? Maybe a spybot filter or something. Any suggestions are welcome. Thank you, DMW Thank you for the tip I will try to figure it out from here, again thanks Link to comment Share on other sites More sharing options...
