mysko Posted August 12, 2006 Share Posted August 12, 2006 When i have selected a movie o whatever, and starts the download the whole bitcomet program just stand still and after some Hours nothing happends.. i turned off my firewall but nothing happend. PLS help me EDIT : I downloaded a file on 7 mb and it worked fine, but why cant i download bigger files ? Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 12, 2006 Share Posted August 12, 2006 Please specify, have you tried to run a known good torrent? This problem, when reported by new users is most often due to selecting a dead torrent. A torrent must have seeders, or it will not complete. If you like, I could find you a good torrent to test your client. Suspect Link to comment Share on other sites More sharing options...
mysko Posted August 12, 2006 Author Share Posted August 12, 2006 Please specify, have you tried to run a known good torrent? This problem, when reported by new users is most often due to selecting a dead torrent. A torrent must have seeders, or it will not complete. If you like, I could find you a good torrent to test your client. Suspect yes pls do that for me Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 12, 2006 Share Posted August 12, 2006 here is a link for a startrek dvd I encoded last year. http://newvoyages.mine.nu:1701/torrent.htm...1860b038cc045b5 It is well seeded and should give good speeds. Suspect Link to comment Share on other sites More sharing options...
mysko Posted August 12, 2006 Author Share Posted August 12, 2006 here is a link for a startrek dvd I encoded last year. http://newvoyages.mine.nu:1701/torrent.htm...1860b038cc045b5 It is well seeded and should give good speeds. Suspect The real problem is, when i download anything big, like 600 mb the client program stops, so i need to shut it down. Well the startrek torrentfile works, But extremly slow. But i was trying to get V-for-vendetta and it was 37 seeders dident work :S Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 12, 2006 Share Posted August 12, 2006 This torrent I posted is about two gigs in size. Please report if it is working. Suspect Link to comment Share on other sites More sharing options...
mysko Posted August 12, 2006 Author Share Posted August 12, 2006 This torrent I posted is about two gigs in size. Please report if it is working. Suspect Working, but slow, and i cant download a movie that has 37 seeders 6.7 gig size Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 12, 2006 Share Posted August 12, 2006 ok, I am at a loss trying to understand what you would like help with... if your issue is with speed, then please reply with the max upload and download speeds your isp provides, and what appears to be your observed max upload in your client. I can help you adjust your client to perform better. Suspect Link to comment Share on other sites More sharing options...
mysko Posted August 12, 2006 Author Share Posted August 12, 2006 ok, I am at a loss trying to understand what you would like help with... if your issue is with speed, then please reply with the max upload and download speeds your isp provides, and what appears to be your observed max upload in your client. I can help you adjust your client to perform better. Suspect Ok i will explain my problem now. When i try to download a file from www.softtorrents.org i cant download it. my bitcomet just stops and "ctrl + alt + del" it says bitcomet does not respond" so i whanna fix that! nothing more. Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 12, 2006 Share Posted August 12, 2006 Ok, I now understand that your bit comet program becomes unresponsive after running for an extended period of time. Can you then restart the client and continue the download? Also, does it function correctly if its the only application running? or when its running with other programs? Please reply with your bit comet version, and your system specs. Suspect Link to comment Share on other sites More sharing options...
mysko Posted August 12, 2006 Author Share Posted August 12, 2006 Ok, I now understand that your bit comet program becomes unresponsive after running for an extended period of time. Can you then restart the client and continue the download? Also, does it function correctly if its the only application running? or when its running with other programs? Please reply with your bit comet version, and your system specs. Suspect My bitcomet version is 0.70. dont know what system specs stands for ^^ but you tracker worked fine! can u find a good tracker for "V-for-vendetta, and Pirates of carabbien dead mans chest" pls :) Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 12, 2006 Share Posted August 12, 2006 Its not appropriate to post links to illegal downloads in this support forum. I will refer you to some torrent sites via PM to help you find what you are looking for. Suspect Link to comment Share on other sites More sharing options...
mysko Posted August 12, 2006 Author Share Posted August 12, 2006 Its not appropriate to post links to illegal downloads in this support forum. I will refer you to some torrent sites via PM to help you find what you are looking for. Suspect Can i have your msn ? then we can talk faster :) Link to comment Share on other sites More sharing options...
Dark_Shroud Posted August 12, 2006 Share Posted August 12, 2006 It seems to me this person needs to do through our settings guide and configure their firewall. Link to comment Share on other sites More sharing options...
