Bitcomet Not Connected
cinna
I've always been using bitcomet to download files, but one day, it just stopped working. After a while, I upgraded it to 0.7 and it still doesn't work. On transfers, it always reads cannot connect to tracker and on web, it can't connect to any sites at all. I've tried to disable the firewall and made sure the TCP and UDP tabs are enabled, still doesn't work. :angry: Also, it says that the DHT isn't connected even though I've already enabled the DHT tab. Please give suggestions to how to sovle this problem. Thanks~
First, ignore DHT until you've got the other problems solved. It's nice but not necessary.
This sounds like you have a firewall blocking outgoing traffic from BitComet. If you have an existing rule, try deleting it and creating a new one. Some firewalls treat a new version as a whole different program that they don't have a rule for. That may have happened to you.
