Vsop Posted August 16, 2006 Share Posted August 16, 2006 I've got ADSL 256 kb/s, Sagem modem (F@st 800/840) with v3.0 drivers (Installed as USB ADSL Lan Adapter) I use cFos v.7.0 to connect internet, BitComet 0.7 to download, and Windows Xp with Sp2 as OS. I know about the connection limit, and I've already set it from 10 to 100. When I'm downloading ANY torrent, I can't connect to ANY of the peers (I've tried with many different torrents) , although there are plenty of them. I usually have 20 kb/s dl speed and 10kb/s upload speed, but now they're both at 0. Turning off the XP firewall doesn't change a thing. These are the my settings: Connection Global Global max download rate = unlimited Global max upload rate = 10 kb/s Task Schedule Max simultaneous download tasks = 100 Automaticly start a new task if download rate below = 10kb/s Listen port=15898 (chanching it doesn't change anything) No proxy Task Do not prompt when add new ask = no Allocate disk when add new task = no Add .bc! extension for incomplete file = yes Delete 0 byte files when task is removed = yes Display task delete confirm dialog = yes When download is finished Hash-check again when download task is finished auto stop task when share ratio reaches = no limit do not auto stop task when seeds less then = 5 shut down computer when all task are finished and auto stopped Upload Maximum upload rate per task = no limit Minimum upload rate per task = no limit Minimum upload rate per seeding task = 3 kb/s Chatting is disabled Avanced Check for updates on startup= yes default bittorrent client = yes disable torrent confirm file download dialog = yes set hash check thread to low priority = yes add dht network as backup tracker =yes add backup tracker if connection isn't estabilished in 1 minute backup trackers = none Connection Enable DHT network = yes Enable Nat/firewall configuration in ics/icf (xp only) = yes Enable unpn port mapping (xp only) = yes Remove ports on Nat/firewall (xp only) = no Maximum connections per task = auto Connections to keep per task = auto Global maximum upload slots = auto Global minimum upload slots = auto Socket send buffer size = auto Socket start interval = 300 ms Max open tcp connections = 100 use nat traversal via udp = automatic protocol encryption = auto detect Ip rules Enable reporting lan ip to tracker = yes enable ip filter file ipfilter.dat (compatibile with emule) = yes max sessions per ip for downloading task = 3 max sessions per ip for uploading task = 1 Disk cache minimum disk cache size = 100 mb maximum disk cache size = 200 mb shrink disk cache if free physical mermory lower than 50 mb auto choose cache size in given range = yes If anyone need more config specification, fell free to post a reply If anyone can tell me how to improve my Bitcomet performance, basing on my configuration please post a reply too. Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 16, 2006 Share Posted August 16, 2006 As far as increasing your download speed, with 256kb/s max download provided by your ISP, the max you could download measured in Bytes is 32kB/s. Out of that you may be about to adverage 25kB/s if you adjust your settings a bit, but any more would require upgrading your internet connection. Now on to the real problem... Something has changed to block your connection, most often this is firewall related. I will assume its not a port issure since you have tried changing ports. I would also recommend you get a better firewall then windows firewall. Sygate is perhaps the most secure, Mcafee is good, and very easy to use. Now, as for exactly what happened to cause your bit comet to stop connecting is hard to say. Did you install any new hardware or software at the time it stopped? Have you tested a known good torrent? I'm also sorry to say I personally don't have experience with your hardware, so can't offer advice specific to this (perhaps other here might know of any issures) Am I correct that you are not using a router?, just a direct usb connected modem? When bit comet runs, are you getting any tracker errors? or no connection at all? Suspect Link to comment Share on other sites More sharing options...
Vsop Posted August 16, 2006 Author Share Posted August 16, 2006 Thanks for such a quick reply. 1. I'll try to use another firewall 2. I didn't istall any new software 3. All my problems started when i took my hard drive to a friend of mine, and connected it to his computer as a slave disk (to copy a real big file). Maybe I've catched a virus or sth but my antivir soft (avast! with latest virus database) didn't detect anything. 4. I don't recive any tracker problems at all (everything is ok but the connection.) 5 Since my last post Bitcomet finally connected to some peers, but didn't start downloading or uploading data. 6 I've got Celeron 1.2 GHZ, 256 Mb Sdram, sapphire radeon 9200 128mb 128 bit ram and 160 GB Segate hard disk 7 I Am sure that i use direct USB adsl modem. PS: Thank you. Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 16, 2006 Share Posted August 16, 2006 well, we can be sure that something happened when your hard drive was removed, and reinstalled. Here is a test of antivirus you might be insterested in reading. http://www.virus.gr/english/fullxml/defaul...d=72&mnu=72 Avast detected 76% of the viruses tested. I would run a scan with kaspersky (99% detected), or another top performer. I am also wondering about your update that you can now connect to tracker. I suggest you try running a torrent that is known to be very healthy (I can recommend one if you like) Suspect Link to comment Share on other sites More sharing options...
Vsop Posted August 17, 2006 Author Share Posted August 17, 2006 Thanks! It was some kind of spyware that was blocking the ports. Now I can down/up load data using bitcomet. Link to comment Share on other sites More sharing options...
Dark_Shroud Posted August 18, 2006 Share Posted August 18, 2006 You should consider using Ethernet connections for your modem it will make things easier and let XP do the work of connection without additional junk. Also, you don't need to mess with the patch for the limit. Thats turned out to be a big misconception. You can read about it in out guides setion here, tcpip.sys limit aka XP SP-2 limit. You need some kind of firewall when connection to the internet. The Windows one will work fine. If you don't want to use that one then you can use Kerio Personal Firewall, its free. Link to comment Share on other sites More sharing options...
