mizzshaun Posted August 16, 2006 Share Posted August 16, 2006 i'm fairly new to bit comet and what not but lately i have been downloading things on bit comet. all my files reach 100% but when i go to play the movies. etc either it looks like the files are incomplete or it crashes...can anyone help???? it wont let me attach anything but the files end in .bin and .cue Link to comment Share on other sites More sharing options...
the_protagonist_01 Posted August 17, 2006 Share Posted August 17, 2006 i'm fairly new to bit comet and what not but lately i have been downloading things on bit comet. all my files reach 100% but when i go to play the movies. etc either it looks like the files are incomplete or it crashes...can anyone help???? it wont let me attach anything but the files end in .bin and .cue Dude, none of your files are incomplete. .bin files suck! I dont even know how to play them. I tried to find a program that could play them, but i failed :(. Anyway, download mpegs, mpeg 4's, avi's, real media, and wmvs they are all legit. Link to comment Share on other sites More sharing options...
cybrwolf Posted August 17, 2006 Share Posted August 17, 2006 I don't know about whether your files are incomplete but you can play bin files with the VLC media player. Link to comment Share on other sites More sharing options...
kluelos Posted August 17, 2006 Share Posted August 17, 2006 These are disk images, in the format that used to be widely used for CD's. There are several other disk image formats in popular use. A disk image is just what it says - an image of the disk. There is nothing to specify what's contained in that image, it could be anything that can be put on a disk. Could be a game, a collection of MSOffice documents, a movie, an audio CD, a Linux distro, a MacOS application, anything that can be put on a disk. If you know that it's a movie, or you know that it's an audio CD, then you can use VLC player from Videolan.org to play the image directly. If you don't know, or don't like/want to use VLC, then you must treat it as an image. You can either burn it to a CD/R, or you can mount it in a virtual drive and use it that way. In order to mount it, you can use Daemon Tools, or you can use Alcohol 120%, both very popular applications for the purpose. There are some others. This is also what you should do if you know that it's a game, or PDF files or anything else. Just mount it in a virtual drive, and it will act just as if you have another CD/DVD drive with a disk in it. Link to comment Share on other sites More sharing options...
realutd7 Posted August 17, 2006 Share Posted August 17, 2006 also make sure you are playing the downloaded file, not the .torrent file to be sure you're playing the downloaded file, right click on the file in BitComet and select Browse Downloaded Directory. the files should be in there Link to comment Share on other sites More sharing options...
slackie Posted August 17, 2006 Share Posted August 17, 2006 nero plays .bin files ....you cuold also just rename the bin file .mpg....the cue file is the instruction list for burning Link to comment Share on other sites More sharing options...
Dark_Shroud Posted August 18, 2006 Share Posted August 18, 2006 Don't do that. :wacko: Renameing disc images is asking for trouble. Use VLC, burn it, or mount it. Link to comment Share on other sites More sharing options...
