sarg2006 Posted May 31, 2006 Share Posted May 31, 2006 hi there, lastnight i was downloading somestuff ?(games).. and i doono what happened but when i woke up! all of them were 100% done..which is normal, but the problem is i got a "RED X" instead of the usuall green cirlce..i opened it, and couldnt extract the RAR files..most of them are still XXX.rar.bc! which means they're still downloading..ive ip'ed the pic online.. can somoene check it and tell me whats wrong? thanks :) Link to comment Share on other sites More sharing options...
Gucio Posted May 31, 2006 Share Posted May 31, 2006 It usually means that some error occured... Maybe out of disk space ? Olders BitComet behave this way, showes up u got 100% and in files list u got Error: Out of disk space... Obviously i can be wrong but check this in first place. Link to comment Share on other sites More sharing options...
bitdave Posted May 31, 2006 Share Posted May 31, 2006 Gucio is probably right, since you have a bunch with red X's then your probably out of disk space. For the complete answer check the FAQ link in my sig. Also you might want to look in the Preferences -> Task there is an option to "allocate disk space before downloading" which may help you keep from filling your drive halfway through a download Link to comment Share on other sites More sharing options...
