qwertywraith Posted August 19, 2006 Share Posted August 19, 2006 Hey, I just finished a LONG download and I would like to keep seeding. Right now there are 4 peers but no other seeds, but for some reason I'm not connecting. It's indicating I'm uploading with an upload arrow and I'm connected to 4 peers, but I haven't uploaded anything. While I was downloading I uploaded 5 times what I downloaded. I've seeded other torrents without far less trouble. I'm downloading at the same time and most of my upload speed is dedicated there. Could that be an issue? Should I dedicate time to JUST seed? So can anyone help me seed? Link to comment Share on other sites More sharing options...
bitdave Posted August 19, 2006 Share Posted August 19, 2006 You can right click on the torrents and go into their properties There you can set a min and a max upload rate That way you can split your upload bandwidth between the two torrents Link to comment Share on other sites More sharing options...
qwertywraith Posted August 19, 2006 Author Share Posted August 19, 2006 I've been tweaking my upload maximums. Today for example, I had 2 finished torrents I wanted to seed, and a torrent I started downloading. No matter how low I put the upload speed on that download the other two seeding torrents would not get ANY speed at all. Link to comment Share on other sites More sharing options...
bitdave Posted August 20, 2006 Share Posted August 20, 2006 Sometimes your not always needed for uploading. It may be the case that no peer on your seeding task needs your upload(especially if you havent portforwarded). Do you get any "Remote" peer connections??? In any case when setting the individual torrent upload settings you should set both the min and the max, not just the max Link to comment Share on other sites More sharing options...
