wiskyjon Posted August 23, 2006 Share Posted August 23, 2006 Any idea on why I have these errors on XP Pro SP2 system? Default tracker optimization rules file loaded. IP rules file: ipfilter.dat loaded, 0 entries. Start Listening at TCP Port:14624 Start Listening at UDP Port:14624 BitComet 0.70 is running on: CPU : Intel® Pentium® 4 CPU 2.40GHz 2392 MHz RAM size : 1.49 GB OS Version: Microsoft Windows XP Professional Service Pack 2 (Build 2600) Windows XP WF Status: TCP Port is opened in Windows Firewall. Windows XP WF Status: UDP Port is opened in Windows Firewall. Update Local IP: 72.135.10.212 Windows XP ICS Status: cannot find working ICS. Windows XP UPnP Status: device not found! Link to comment Share on other sites More sharing options...
Dark_Shroud Posted August 23, 2006 Share Posted August 23, 2006 Those aren't errors. There settings you don't have/need. You can turn off UPnP as thats for routers that support UPnP. ICS is for Internet connection shareing. Unless you use Windows Firewall (ICF, they share a setting) you can turn that off as well. And from the looks of your settings you can turn the IPfiler.dat filter of as well since you don't have a list loaded. Is easier/better to run Peer Guardian for that anyway. Link to comment Share on other sites More sharing options...
