M1ke Posted August 25, 2006 Share Posted August 25, 2006 I,ve been using azureus and bitcomet for quite some time, but since a week my download speed on azureus can,t get higher then 10 kb/s and on bitcomet not higher then 35kb/s. in the lower right corner in says: DHT not connected. I,ve tried the bitcomet beta version, and the DHT is connected but it says DHT connected node:0 what does that mean? and on the beta version its also not going higher then 40 kb/s whats the problem? i hope someone can help me Link to comment Share on other sites More sharing options...
Zickler Posted August 25, 2006 Share Posted August 25, 2006 I also have the same probleme. i can't load down files or movies because at the status-line is standing DHT not connected. I hope someone can help me soon!! Link to comment Share on other sites More sharing options...
Dark_Shroud Posted August 25, 2006 Share Posted August 25, 2006 You do not need DHT to download. If you guys had done a forums search or checked our faq you'd be a lot less up tight right now. Check your firewalls and make sure UDP connections are allowed on the port you're using for BitComet. Link to comment Share on other sites More sharing options...
kluelos Posted August 25, 2006 Share Posted August 25, 2006 It sounds very much like your firewall settings have changed or a new firewall added, and as a result, your listening port is being blocked. Being blocked for TCP accounts for the slowdown, and being blocked for UDP accounts for the DHT issue. Link to comment Share on other sites More sharing options...
