DHT and start problems
Hi there, I have just started using Bitcomet and for the past few weeks have been downloading albeit at a very slow pace. I still have a grey circle for the DHT saying it isnt connected, have no idea how to fix that as I have enabled it in the options section. Also this morning when I opened Bitcomet I couldnt get the tasks to start again. I have gone through all the options, highlighted the tasks, pressed the start button, gone into options and chosen the start now option and nothing is happening. They arent even searching for connections they just have the dreaded grey circle and are sitting there doing nothing. What went wrong? All help appreciated.
This could possibly mean that your default download directory, or more specifically the directory where that specific torrent is downloading to - no longer exists.
I.e. If your download directory goes to say a removable drive, and your drive has now changed drive letters by itself, or if it's off, BitComet will be able to find where the rest of the download is at.
I have the same prb as Kerr and just checked what you suggested and my settings are in order. Below is my error, pls advise, ty.
Default tracker optimization rules file loaded.
IP rules file: ipfilter.dat loaded, 0 entries.
Start Listening at TCP Port:50003
Start Listening at UDP Port:50003
BitComet 0.70 is running on:
CPU : Intel® Pentium® M processor 2.00GHz 1998 MHz
RAM size : 1.99 GB
OS Version: Microsoft Windows XP Professional Service Pack 1 (Build 2600)
Windows XP WF Status: Not Supported.
Update Local IP: 192.168.1.111
Windows XP ICS Status: WAN IP: 125.24.175.232
Windows XP ICS Status: TCP PortMapping Successfully Added.
Windows XP ICS Status: UDP PortMapping Successfully Added.
Windows XP UPnP Status: Found WANConnectionDevice [Microsoft] [http://www.microsoft.com/]
Windows XP UPnP Status: Found Service: urn:schemas-upnp-org:service:WANPOTSLinkConfig:1
Windows XP UPnP Status: Error occur when Adding TCP Port Mapping!
Windows XP UPnP Status: Error occur when Adding UDP Port Mapping!
Windows XP UPnP Status: Found Service: WANPPPConnection
Windows XP UPnP Status: WAN IP:
Windows XP UPnP Status: Found WANConnectionDevice [Linksys] [http://www.linksys.com/]
Windows XP UPnP Status: Found Service: WANIPConnection
Windows XP UPnP Status: WAN IP: 125.24.175.232
Windows XP UPnP Status: TCP Port Mapping Existed!
Windows XP UPnP Status: UDP Port Mapping Existed!
Ok ignoring DHT. Tracker report says -
Tracker URL - http://inferno.demonoid.com:3390/announce
Retries - 0
Time left - Stopped
Log says -
Start Listening at TCP Port:60002
Start Listening at UDP Port:60002
CPU : Intel® Celeron® CPU 2.50GHz 2492 MHz
RAM size : 190.98 MB
OS Version: Microsoft Windows XP Professional Service Pack 2 (Build 2600)
Update Local IP: 192.168.1.2
Windows XP ICS Status: cannot find working ICS.
Windows XP WF Status: TCP Port is not opened in Windows Firewall.
Windows XP WF Status: add TCP port in Windows Firewall Succeed.
Windows XP WF Status: UDP Port is not opened in Windows Firewall.
Windows XP WF Status: add UDP port in Windows Firewall Succeed.
Windows XP UPnP Status: device not found!
What I dont understand is that I didnt change any of the settings and it was working just a few days ago.
Yeah just one problem with that I dont have the original torrent saved and it doesnt seem to want to save a torrent file from the tasks I have. If I find and save the original torrent again does it mean that I have to start downloading from the beginning?
No, when you start the torrent again, it will scan (rehash) the exsisting files (providing you use the same location to save to), and continue the download.
keep in mind that the torrent will only complete if there are seeders present.
If not, then use more care in selecting the torrents you download.
