Help me
onggiakien2006
do you mean you have opened a torrent? or the torrent has finished downloading??
if you cant open the torrent, just 'save as' the file and then open it with BitComet
if you cant open the finished file, you may just be doing something commonly wrong. right click on the finished file in bitcomet, select 'browse downloaded directory' and the file that shows is the file you open
.daa files (direct access archive) are made using "powerISO"
It is basically a "disc image", which can be burnt to disc, or mounted in virtual cdrom drive.
You can download a trial version direct from them.
Google can find it for you.
ps. there are many working keygens availble on torrent sites for this as well.
