bitcomet download speed slow
tonez
im using windows xp sp2, with zonealarm security v.65.
i used to get downloading speed of 300+ kB/s in total. but now, after ive added a internet router, its been really slow, and all the initiations are LOCAL and 2-3 NAT traversals.
i dunt understand what may be going on.
i tried lvllord and it still havent help.
can someone tell me wuts going on? cuz im confused.
THANK U
If this problem is only since you installed router, then you don't have your port forwarding setup properly.
Also, if you havn't already, you should set a static IP address in windows.
Step by step guides with screenshots are availble at Portforward.com
im still getting all local connections.
maybe im doing the static ip address thing wrong? can u just make an ip address up urself? or do u use the ip address u got from ipconfig/all?
and i only have one DNS address rather than the 2 shown in the diagram. from port forward.
i dunno if this should matter..but i have a speedstream 5200 as my modem.
