Help
You can go to control panal, "add and remove programs"
"your uninstaller" is also a good program for this.
also, there is a program that "dark shroud" (staff member here) recommends, I'm sure he will find this post within the next day or so.
here is some info on "your uninstaller"
Your Uninstaller <--- click me
You could also find it on many torrent sites (not that I would recommend downloading pirated software) hehehe...
ps. many people install the newer version on top of exsisting version, but I prefer to remove the old versions of programs before installing new versions when possible.
