andyflemin Posted September 2, 2006 Share Posted September 2, 2006 Hey guys, I've had a problem with the "DHT not connected", I found that this can be resolved by setting up port forwording for bit comet on my router. I just need an IP Address and a starting port and ending port number. I'd appriciate any help. Thanks, Andy Link to comment Share on other sites More sharing options...
Dark_Shroud Posted September 3, 2006 Share Posted September 3, 2006 www.portforward.com FYI, you only portforward if you have a router. This is usually a settings problem with people's firewalls. You need to make sure your firewall is allowing UDP traffic. Link to comment Share on other sites More sharing options...
andyflemin Posted September 3, 2006 Author Share Posted September 3, 2006 Thanks I've configured my router according to the website but the problem is still there even when I turn my firewall off, would really appriciate anymore help. Thanks, Andy Link to comment Share on other sites More sharing options...
bitdave Posted September 4, 2006 Share Posted September 4, 2006 What firewall? -some of them even when you turn them off still block things. do you still need help? Link to comment Share on other sites More sharing options...
andyflemin Posted September 5, 2006 Author Share Posted September 5, 2006 I use the free version of Zone Alarm, yes I would be really gratefull for any help at all, Thanks very much, Andy Link to comment Share on other sites More sharing options...
Dark_Shroud Posted September 5, 2006 Share Posted September 5, 2006 That's your problem. ZA is trash and you can't turn it off, you have to uninstall it. Just get rid of it. If you have a firewall router then you can just use the SP-2 firewall. If you want more then you can get the free version of Kerio. Link to comment Share on other sites More sharing options...
