No connection
Myneani
Hi.
I've used BitComet 0.70 for quite a while now, and there's been nothing wrong with it, but all of a sudden there's no connection. I've checked the internet connection and it's still connected.
Down in the corner it says "DHT not connected". Can't really figure out what that means, but it's always said that, even though BitComet was connected, so I just thought it was some mistake...
Anyway, I've tried restarting the computer and uninstall and install again several times, and it hasn't worked, so maybe you could give me some sort of advice of what do to..?
Thank you.
This sounds like firewall is blocking you, have you made any changes to your computer when this happened?
Its also possible that the torrent/s you have selected arn't active.
You might want to try a known good torrent.
Wait... It actually started working now. What the h***. :huh: I didn't do anything and it started working again.. That's just... weird. Let's hope it holds up this time. <_<
But thank you all very much for all your help, I really appreciate it.
