Help video probleme`s
jayjay
i`m using win media player and the codex i took from windows download.
i`ve try nero and steel the same thing....the tv serie i try to run is vanished episode3.
i already saw the first and the 2 episode and everything was ok....now i don`t no what happen.
Lets try this, download & install CCCP with Media Player Classic. This should allow you to play your files. I say to install Media Player Classic (you don't have to if you don't want to) because WMP 10 still has a few quirks with some file types. But WMP 11 works perfectly so far.
Hy!!! I fix the probleme`s i uninstall everything and re install and boom ....
thank<s for your help......
someone told me about any dvd and i want to try it......i download the version 6.0.5.1 and i dont no where to put the key !!!! to make it work . can you help
