peers connected but not downloaded from
hjzhawii
Ok, so in the main window, it says i'm connected to a certain number of peers. When i click the peer tab, i see the ip of ppl i'm connected to. The thing is, Not every1 of them are uploading stuff to me, in fact, most of them are 100% (seeds i assume) and have blank under the KB/s DN, whilst only a few have non-blank eg 5 kb/s etc
I just wanna ask, if this is normal, or is it just me?
I would upload a screeshot of the thing i'm saying abt, but my internet's f***** up right now and i can't get into imageshack. Maybe later.
the 100% bit only shows how healty is you're torrent if it's under then the torrent isn't completely healty, well you should check how many seders there are, the torrent might have only 1 seder which is uploading hard it happens the same to me...,and depends on firrewalls and other stuff...(this is a big chain of events)
