not connecting.....
It usually means that something changed, and now your firewall(s) is blocking outbound traffic from BitComet. Many software firewalls will treat an upgrade as a whole new application, for which they have no rule, rather than an upgrade to which they should apply an existing rule. Your firewall's log should tell you if that is the case. If you have disabled logging then you should re-enable it for situations like this. You will very likely need to make a new rule to permit Bitcomet through the firewall(s)
