DNA Posted June 2, 2006 Share Posted June 2, 2006 Where do I find, and how do I use private trackers >___> Link to comment Share on other sites More sharing options...
Soraiya Posted June 2, 2006 Share Posted June 2, 2006 Private Trackers are usually not given publicly. Rather when you upload a torrent, the torrent search engine itself will add the tracker into your torrent. So...you can try: www.isohunt.com www.torrentspy.com www.mininova.org Most search engine sites will have their own trackers. If however you want to use a tracker without registering at the search engine site, try this tracker out: http://tracker.prq.to/announce Link to comment Share on other sites More sharing options...
Dark_Shroud Posted June 2, 2006 Share Posted June 2, 2006 That tracker is for the Pirate Bay, they are down at the moment. Link to comment Share on other sites More sharing options...
