helpme Posted September 12, 2006 Share Posted September 12, 2006 I have BitComet Verison 0.70 and the only problem is for some reason my tracker url keeps getting deleted when I close my BitComet. For example I am downloading something and then stop the download and close Bitcomet and turn off my computer, and when I restart my computer the next day or so the tracker url won't be there and won't let me return to downloading the torrent. I have to delete the torrent from the queue not the entire one and redownload the torrent and do a hash check and then it will continue downloading the torrent and the url will be in the tracker info on my bitcomet application. Is their anyway of locking the url into the tracker permanently because this is becoming very annoying having to do this a couple times now. Any advice will be very appreciated, and thank you for your time. Link to comment Share on other sites More sharing options...
bitdave Posted September 12, 2006 Share Posted September 12, 2006 Very wierd, never experienced this before. Have you tried uninstalling Bitcomet using this method. Also make sure that nothing in Bitcomets folder is set to read only. Link to comment Share on other sites More sharing options...
