A problem!
Kait
I have a problem with the download velocity, when i click on a torrent, he start to intent
connect, but when it connect he start to download at 2~4kb/s... the last weekend it download
at 60~100kb/s, why downloads at this velocity?
in bit torrent protocall, the speed in which you can download is often limited by the upload speed that other peers provide.
I suggest you check the settings guide, and if your using a router, be sure your ports are properly forwarded to the respective computer.
Slow torrents are mostly due to people that run more then one torrent at a time (without upload rates to support doing this)
