LeFTy Posted September 16, 2006 Share Posted September 16, 2006 Howdy how from a newbe on the forum... Well here it goes.. i got my self a new computer and installed BitComet But when i try to download something, nothing happens :o :o :o But i says "Not Loginned in" on the bottom of the screen? someone nows what to do.... have been trying to find it on the forum but no luck :( LeFTy Link to comment Share on other sites More sharing options...
scarecrow_76 Posted September 16, 2006 Share Posted September 16, 2006 (edited) if you made the unfortunate mistake of downloading v0.71 unistall that and download v0.70. that should take care of it! Edited September 17, 2006 by Dark_Shroud (see edit history) Link to comment Share on other sites More sharing options...
Dark_Shroud Posted September 17, 2006 Share Posted September 17, 2006 Stay away from 0.72 as well. Link to comment Share on other sites More sharing options...
Meia Posted September 18, 2006 Share Posted September 18, 2006 i'm juz dl ver 0.72 n i had the same problem as Lefty. why can't use ver 0.72 though it's the latest version...? Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted September 18, 2006 Share Posted September 18, 2006 The latest STABLE version is .70 We are all sorry for the problems members are having with the two newer versions. Suspect Link to comment Share on other sites More sharing options...
Meia Posted September 18, 2006 Share Posted September 18, 2006 The latest STABLE version is .70 We are all sorry for the problems members are having with the two newer versions. Suspect ic, thanks. Q: if i can't find a song via the bitcomet, can i post a post/thread at this forum to get some helps? Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted September 18, 2006 Share Posted September 18, 2006 we allow such posts in the lounge area. Suspect Link to comment Share on other sites More sharing options...
