kc2274 Posted June 3, 2006 Share Posted June 3, 2006 I've downloaded the torrents for some past exams, and i wana b able 2 read them, but all i keep doing is redownloading the torrents... HELP PLEASE!! Link to comment Share on other sites More sharing options...
Dark_Shroud Posted June 3, 2006 Share Posted June 3, 2006 A .torrent file is just a text file with download instructions. You have to open the .torrent file in BitComet to download the real file(s). Link to comment Share on other sites More sharing options...
Soraiya Posted June 3, 2006 Share Posted June 3, 2006 o.O Once you've downloaded the torrent files to a location you know. Open BitComet --> File --> Open Torrent Locate that torrent file that you've downloaded, and BitComet should automatically open the file up. It doesn't matter if your PC cannot view torrent files. If you get an error upon the opening of a file, try re-downloading the torrent file. If you keep re-downloading, and you keep getting the same error, i.e. InfoHash errors, then it's more than likely that the torrent itself is corrupt. If this is the case...you may need to locate another torrent. Link to comment Share on other sites More sharing options...
