lilaznviper Posted September 20, 2006 Share Posted September 20, 2006 i just began using bitcomet and the problem im getting is that its hoging up a lot of my cpu usage like 50+ is this normal Link to comment Share on other sites More sharing options...
scarecrow_76 Posted September 20, 2006 Share Posted September 20, 2006 i just began using bitcomet and the problem im getting is that its hoging up a lot of my cpu usage like 50+ is this normal what version are you using? Link to comment Share on other sites More sharing options...
lilaznviper Posted September 20, 2006 Author Share Posted September 20, 2006 .70 Link to comment Share on other sites More sharing options...
scarecrow_76 Posted September 20, 2006 Share Posted September 20, 2006 mine uses up to about 33% but goes up and down all the time. Link to comment Share on other sites More sharing options...
lilaznviper Posted September 20, 2006 Author Share Posted September 20, 2006 hm... dunno then my still uses 50+% and i can't do anything on my computer while im using it Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted September 20, 2006 Share Posted September 20, 2006 by "can't do anything" are you referring to browsing or internet activity? or you can't use any of your computers programs. The former can be helped by bandwidth limiting, the latter may require upgrading your memory or fine tuning your windows. Suspect ps. Please reply with specs of your system Link to comment Share on other sites More sharing options...
lilaznviper Posted September 21, 2006 Author Share Posted September 21, 2006 can't do anything as in cant listen to music using winamp.. ican do it it but its choppy music as it skips and everything specs: athlon xp 2400 1gb ddr400 730gb Link to comment Share on other sites More sharing options...
Starfire Posted September 21, 2006 Share Posted September 21, 2006 can't do anything as in cant listen to music using winamp.. ican do it it but its choppy music as it skips and everything specs: athlon xp 2400 1gb ddr400 730gb I am also having problems. I can't use zoomplayer to watch a video because as soon as I start it, it maxes out my CPU and the audio and video will be choppy. It's fine if BitComet isn't running. I tried upgrading to the new version but my computer did not like the new version of BitComet. I'm running version 0.70. Athlon 1.1ghz 640MB of PC133 RAM Windows XP Home Edition 160 GB System HD 160 GB Storage HD Link to comment Share on other sites More sharing options...
