Lozg_89 Posted September 23, 2006 Share Posted September 23, 2006 Could ny one tell me why my download is at 3 kbs yet my upload(s) are at 70 kbs i am meant to haf a 2mb connection yet the faster download speed i can get is bout 40 kbs on a good day please help i have redueced my max upload to 6kbs this does not seem to work please help LUV LOZ XX Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted September 24, 2006 Share Posted September 24, 2006 Hi, reducing your max upload helps only if your upload bandwidth is near max. The idea is to upload as much as possible, without making your client slow to respond to the requests. If your upload runs at about 70kB/s (which is better then adverage), then I would set your max upload at about 55kB/s while downloading. Now, if you are using a router, you must forward your listening port. portforward.com has guides with pictures for most routers. you will also want to set a static IP address in windows. If your not using a router, then these steps are not necessary. In either case, you should be using a listening port in the 50,000 to 60,000 range. I would also find a very healthy torrent to test your client. I can recommend one if you like. Suspect Link to comment Share on other sites More sharing options...
