Harris19 Posted September 25, 2006 Share Posted September 25, 2006 I have downloaded finaly fantasy 7( the game) but i have a problem. The file which is needed for the setup is called setup-1.bin but in the folder its called setup-1.bin.bc! and it says its not full downloaded. Is there anyone that can help me?? PLZ!!! Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted September 25, 2006 Share Posted September 25, 2006 it sounds like the file is indeed not finished downloading. If your client lists it as done, then I suggest you do a manual rehash of the files. If the file IS in fact done, you can remove the .bc! but only if you are SURE it is finished. Suspect Link to comment Share on other sites More sharing options...
Harris19 Posted September 26, 2006 Author Share Posted September 26, 2006 I started the download again without deleting the files of the game from the downloads folder and it started downloading again the setup-1.bin.bc! file but when it downloaded 20% of the file, did the same thing. It said that its 100% completed but on the right of the download it had the red X and i couldnt setup the game. Is the file corrupted?? But how can this happen?? All torrents sites has the same ff7.torrent. PLZ HELP!!!! Link to comment Share on other sites More sharing options...
