tgk Posted September 26, 2006 Share Posted September 26, 2006 morning, can someone tell me how to get the max of 150 open port's. i have troubles using voip calling and i could be that there are to many ports open. thanks Link to comment Share on other sites More sharing options...
Dark_Shroud Posted September 28, 2006 Share Posted September 28, 2006 You are mistaken on an issue. Port are only closed by your firewall. And programs should only use 1 port for or a few ports for connections. You should give a lot more information about what you're doing. Like your OS, your security software, do you have a router, if so what kind. Link to comment Share on other sites More sharing options...
