Help me!!!
Lalena
I have been downloading Ranma 1/2 season 5, and because of the speed it took a few days to get it up to 50% Finally when I got some speed on the download I had to exit BitComet. And when I opened it again to resume the transfer(as I did many times before) The task was suddenly gone! I dont know where the heck it is! Can someone please help me to find it and tell me how to resume it? I DO NOT want to restart the transfer, as it took that long time to get so far. So where is it?? ;_;
I also have another question: I had this download that had finished. And when I tried to find the downloaded files in the 'downloads' folder, it was gone! I can't find it! But the (undone)files from Ranma 1/2 season 5 are there! This is some weird shait... Plz help me if you know what I can do about my problems .. I'm begging you
first, at this time, don't use any version newer then .70.
For the incomplete torrent, you can restart it just as you did before. If it doesn't scan (rehash) the files and continue, do a manual hash check and it should be fine.
