dessygee Posted October 2, 2006 Share Posted October 2, 2006 hello there can any1 help to play a downloaded movie the movie is get rich or die tryin dvdrip.xvid-deity also wot is the best software on how to play downloaded movies need a software for other files thnx Link to comment Share on other sites More sharing options...
hanen87 Posted October 2, 2006 Share Posted October 2, 2006 1st u should install XVID video codec seems ur video file is encoded with that codec as for the best player, i would suggest VLC player where u can find it at http://www.videolan.org/vlc/ Link to comment Share on other sites More sharing options...
dessygee Posted October 2, 2006 Author Share Posted October 2, 2006 1st u should install XVID video codec seems ur video file is encoded with that codec as for the best player, i would suggest VLC player where u can find it at http://www.videolan.org/vlc/ dont have a clue how 2 work it soz Link to comment Share on other sites More sharing options...
hanen87 Posted October 3, 2006 Share Posted October 3, 2006 huh.....get xvid codec here --> http://www.free-codecs.com/download/XviD_Media_Codec.htm n read the instruction Link to comment Share on other sites More sharing options...
Dark_Shroud Posted October 3, 2006 Share Posted October 3, 2006 If you are using VLC Player you do not need to install codecs. VLC won't use them because VLC only uses internal codecs. So either get VLC or CCCP. Link to comment Share on other sites More sharing options...
