dan_jc Posted October 14, 2006 Share Posted October 14, 2006 Hi ive just downloaded a ps2 game once extracted theres two folders a Bin/Cue folder, what do i need to burn this as i have burned using alcohol 120 and the game loads and then doesnt do anything else, can anyone help , thanks. Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted October 14, 2006 Share Posted October 14, 2006 Alcohol or nero can burn .bin/.cue disc images. Do you have a "modded" ps2? if not, then you won't be able to use downloaded discs. Suspect Link to comment Share on other sites More sharing options...
dan_jc Posted October 14, 2006 Author Share Posted October 14, 2006 (edited) yes i do, well thats what i have thought but it doesnt work? i used alcohol should i try something else? how would i do it on nero? Edited October 15, 2006 by Dark_Shroud (see edit history) Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted October 14, 2006 Share Posted October 14, 2006 I posted a guide for burning .bin/.cue with nero in our guides section. Link to comment Share on other sites More sharing options...
dan_jc Posted October 14, 2006 Author Share Posted October 14, 2006 I posted a guide for burning .bin/.cue with nero in our guides section. i have nero startsmart on my computer is this it? if so what do i click on, theres make an audio cd,bootable cd etc etc, thanks. Link to comment Share on other sites More sharing options...
