Cybertoxic Posted June 7, 2006 Share Posted June 7, 2006 i think there should be an option to download files by their torrent order meaning still downloading normal but lets say the torrent is 100 files? all 1 mega each instead of 1% torrent being 1% of all it will be 1 file 100& get it? or do i need to explain better? Link to comment Share on other sites More sharing options...
Soraiya Posted June 8, 2006 Share Posted June 8, 2006 So, basically if a torrent has numerous files within it, i.e. 100 files. You want BitComet to be able to download numberwise i.e. Downloads 1st file, then 2nd file, etc Is this it? ^_^ Link to comment Share on other sites More sharing options...
Dark_Shroud Posted June 8, 2006 Share Posted June 8, 2006 If that's it then set priority for the files. The thing is the protocol manages the swarm by the pieces not the file. To make it vary simple its rarity of the pieces thats most important. And lets not get started on what if they're using Super/Initial seed settings. Link to comment Share on other sites More sharing options...
aimee Posted June 14, 2006 Share Posted June 14, 2006 you can set priority for different files or you can disable and enable some files to get what you want most. Link to comment Share on other sites More sharing options...
