PLEASE!! HELP ME!! - "TECHNICAL" BC TROUBLE
kanomann
Hello!
Im a user of BitComet and I have a trouble. The matter is that I was downloading a file, but suddenly I made a mistake and I deleted the task, bot not the files. Now, I can't continue downloading my incomplete files, at least, I don't know how, so if you can give me a way to "resume" my downloads I'll be so grated. I still have the origin .torrent file, is it useful..yet?
THANKS..
CHRIS.
run the torrent files again, using same save location.
if it doesn't continue from current point of completion, do a manual hash check, and it will.
ps. your duplicate post will be deleted, and your account may be suspended or restricted if you make duplicate posts again.
