BitComet 0.71 download help!
Claidie
Hi, I don't know if anyone have this issue before...
I downloading a file at 9% on the 1st day, 2nd day it up till 24% before exit bitcomet. 3rd day when i start bitcomet, the file went back to 9%, it happened same on the 4th day, went back to the 1st day 9%.
Anyone know what happen? I had never encounter this during 0.70
Thanks.
Revert back to the latest stable version 0.70
(just install it right over v0.71)
then with that torrent task stopped rightclick on it and select Manual Hash Check to see how much you really have. After its done then restart that task.
