omiclops Posted October 21, 2006 Share Posted October 21, 2006 Okay so here goes, i downloaded fifa 2007 from bitcomet and compressed it to cso ( using psp compressor v 1.1 ) so it was small enough for my 1gb, so i compressed it and put it on my psp, and turned my psp on, with devhook etc. i emulate at 2.60 and fifa 2007 comes up , a pop up comes up asking me if i want to auto save, clicking yes or no crashes my psp, so then i emulate at 2.71, fifa 2007 dosent come on at all and my psp crashes again.... Please can you help me step by step guide plz !!!!!!!!!!!! If you want the link to the torrent , here it is ... http://www.torrentspy.com/torrent/870770/F..._EUR_PSP_pSyPSP Well thanks for all your help ( if you do help ) Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted October 22, 2006 Share Posted October 22, 2006 I suggest you post your question on a PSP forum. Although your question is in no way improper in the lounge, I just don't know if you will find an answer here, as this forum is primarily for supporting Bit Comet Client. Suspect Link to comment Share on other sites More sharing options...
