u1088 Posted October 26, 2006 Share Posted October 26, 2006 I was using bitcomet since last year without any problem. However since last week, I've experienced some connection issue. My bircomet 0.63 have some difficulty in connect to other peer. The maximum number of peer I can connect is around 30. My upload speed always drop to 2-3kbps even I've set it to 40kbps. I didn't change anything in the meantime. Can anyone help. Thanks. Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted October 26, 2006 Share Posted October 26, 2006 Are you using a router? and have you forwarded your listening port properly? If so, I suggest you double check to be sure your port is open at canyouseeme.org. Otherwise have you checked that this is the case with all torrents? if there are not alot of peers requesting data, then you won't be uploading much, so I suggest you be sure its your problem, not the torrents. Suspect Link to comment Share on other sites More sharing options...
u1088 Posted October 26, 2006 Author Share Posted October 26, 2006 No, I am not using a router, I am using a modem instead. I've double check at canyouseeme.org and it report my port is actually open. My problem is whenever my upload speed drop, so do my download speed. These actually happen to all torrent. All of the torrents I download have more than 100 seeder and 3000 peers. Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted October 26, 2006 Share Posted October 26, 2006 It is possible that your isp is throttling B/T traffic. I suggest you enable protocall encryption if you havn't already. If they are using some of the newly developed detection software, it might be hard to stop the throttling until a new encryption is developed. Suspect Link to comment Share on other sites More sharing options...
