kaikiattan Posted October 27, 2006 Share Posted October 27, 2006 HELp!!!port forwarded!100%.....DHT connected. -the figure under the seed/peer[all] is 9/51[9/511] -connected peers from local and remote seems nice right? but my DL and UL jz stop at 0KB/s!!!pls help.... do i need 2 reformat my pc? Link to comment Share on other sites More sharing options...
bitdave Posted October 27, 2006 Share Posted October 27, 2006 It appears that your connection is fine. If you just started that torrent, give it some time and it should get going. That torrent isnt very well seeded so it might be kinda slow or it may be that your ISP is blocking your peer connections Who is your ISP? I dont think there is any need to reformat your PC (unless you have other major problems) Link to comment Share on other sites More sharing options...
