sakuya_lazuardi Posted October 29, 2006 Share Posted October 29, 2006 I'm newbie. I'm sorry if i asking u a silly question. i've downloading some file until 97%, i stopped it coz my komputer need to shut down after 3 days standby. The problem is when i click start (even right click and then start) the status icon did not change at all from incomplete and stopped. But it works wit another download... Can u help me please?? :( Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted October 29, 2006 Share Posted October 29, 2006 Hi, What version are you using? Suspect Link to comment Share on other sites More sharing options...
sakuya_lazuardi Posted October 29, 2006 Author Share Posted October 29, 2006 I'm using Bitcomet 0.67 Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted October 29, 2006 Share Posted October 29, 2006 If I understand you correctly, when you try to start torrent, its not downloading. Can you tell us how many seeds/peers are listed? both totals you are connected to, and [all]. If you can post a screenshot, this will be helpfull too. Also look if there are any error messages from tracker. Suspect Link to comment Share on other sites More sharing options...
sakuya_lazuardi Posted October 29, 2006 Author Share Posted October 29, 2006 It should be 32 seeds and 132 peers... I dont understand...but it seems the start button ok with the others... Link to comment Share on other sites More sharing options...
bitdave Posted October 29, 2006 Share Posted October 29, 2006 Download and install v0.70 just install it right over your current version, all your settings and torrents will remain then try starting that torrent again any luck? Link to comment Share on other sites More sharing options...
sakuya_lazuardi Posted October 29, 2006 Author Share Posted October 29, 2006 Yup..i've tried that idea b4...but it appears like this... Did i make a mistake?... :( i was indeed stupid for this... :mellow: Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted October 30, 2006 Share Posted October 30, 2006 There is surely something wrong here. I would like to know what windows version you are using, and if your are logged in as administrator, or with admin permissions. If not, and you are logged in as a user without permissions to install applications, you may get an error such as above. Otherwise, I would advise a complete scan of your drives with upto date anti virus, then a few good anti spyware programs, followed up with a scandisc of all hard drives. Something is surely wrong if you can't start a torrent, and can't even install a new version. Suspect Link to comment Share on other sites More sharing options...
sakuya_lazuardi Posted October 30, 2006 Author Share Posted October 30, 2006 I'm using Microsoft Windows XP Home Edition Service Pack 1 Version 5.1 (Build 2600) with Mc Afee for anti virus (never forget to keep it updating) and System mechanic 5 professional for anti spyware. I logged in as administrator and only have one account to logged in... Well, i'm not a high tech person, so can u give me an advice? :mellow: Link to comment Share on other sites More sharing options...
sakuya_lazuardi Posted October 31, 2006 Author Share Posted October 31, 2006 I'm really...really sorry for double posting... Any suggestion about starting my previous download? I felt very sad coz file that i download quite big. Link to comment Share on other sites More sharing options...
bitdave Posted October 31, 2006 Share Posted October 31, 2006 When you tried to install v0.70 was Bitcomet running? -you must exit Bitcomet before trying to install another version. Link to comment Share on other sites More sharing options...
sakuya_lazuardi Posted November 1, 2006 Author Share Posted November 1, 2006 Yup...i've already exit my Bitcomet... :mellow: Link to comment Share on other sites More sharing options...
