nissan350zpimp Posted November 11, 2006 Author Share Posted November 11, 2006 ÜÜßßßÜ ÜÜßß ÜÜÛ ßßßÜÜÜÜ Û ÜÜÛÛÛÛÛÜÛÛÛÜÜÜÜ ßÛÜÜÜÜÜ ÜÛßßßÛ ÜÜÜ ßÜÜ ßÛÛÛß ßßÛÛÛÛÛÛÜ ßßßßßßßßÛÜÛßßßßßßßßßßßÛÛß Üß ÛÜÜÛß Ü ßßßßÜÜ Û ÛÛÛ ÜÛÛÛÛÛß ßßßÛÛÛÛ ßÛ ÜÛÛÛÛÛÛÛÛÛÜ ÜÛÛÛÜ ß ÜÜÛÛÜßÛÛÜÜ ßÜ Û ÛÛÛ ÜÛÛßßßß Üß ÜÛÛßÛÛÛ ßÛß ÜÛÛß ÜÛß ßÛÛÛÜ ÛÛÛ ßÛÛÛÜ Û Û ÛÛÛÜÛÛÜ ÜÜÛÛß ÛÛÛ Ü ÛÛÛ ßÜÜ ÜÛÛß ÜÛÛÜ ßÜ ßÛÛÛÜÛÛÛ ÜÛÛßß Üß Û ÛÛÛßÛÛÛÛÜ ÛÛ ÛÛÛß ÛÛÛ ß ÜÛÛß ÜÛÛÛÛÜ ß ÜÛß ÛÛÛßÛÛÜ Üß Û ÛÛÛ ßÛÛÛÛÜ ÜÛÛÛ ÜÜÛßßÛÛÛÜÛÛÛÜÜÜÜÛÛÛ ßÛÛÛÜÛß ÛÛÛ ßÛÛÜ ßÜÜ Üß ÜÛÛÛÜ Ü ßÛÛÛÛÜßÛÛßßß Ü ßßßßÛÛÛßßßßßßß Ü ßÛß ÜÛ ßßßßß Ü ßÛÛÜ ßßÜÜÜÜ ÛÜ ßßßßßßß ÛÜ ßÛÛÛÛÛÜÜ ßßßßßÛÛÜ ßßÜ ÛÛßßßÛÛ ß ÜÛÛÛßßßßßßßßßÜ ßßÛÛÜÜ Ü ßÜ ßßßÛßßßßßßßßßßßÛÜÜßßÛÛÛÛÛÛÛÜÜÜ ÜÜß ÜÜÛ Ûßßßßß ßßÜÜÜ ßßß Üß ßßÛÜÜÜ ßßßßÛÛÛÛÛßß ÜÛß ßßßßß ßßßßßßÜÜÜÜÜÜÜßß 1 9 1 1 <JED> ÚÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ¿ ³ Razor 1911 proudly presents: ³ ³ Battlefield 2142 ³ ³ © Electronic Arts ³ ÃÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ´ ³ Date: 14th October, 2006 ³ Game Type : Shooter ³ ³ Size: 1 DVD ³ Protection: SafeDisc + Serial ³ ÀÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÙ Game Notes ~~~~~~~~~~ Earth, 2142. As a new ice age depletes the planets resources, two massive multinational coalitions wage a brutal war for the only cause that matters—survival. Armed with a devastating arsenal of futuristic weaponry and gear, including active camouflage, EMP grenades, and sentry guns, plus Battle Walkers and vast airborne bases called Titans, you must coordinate the efforts of your teammates to win the war for Earths last fragile pieces of livable land. With extensive improvements to the groundbreaking Battlefield 2 ranking and upgrade system and the new Titan gameplay mode, Battlefield 2142 brings the franchises award-winning online warfare into a harsh and desperate future. Crack & Installation notes: ~~~~~~~~~~~~~~~~~~~~~~~~~~~ Please note that this release will ONLY work in single-player and LAN mode at this time. Also note that EA decided to use an online-based profile creation, but thankfully your friends at the blade have included a default user profile that can easily be modified to suit your own preferences. ;) Step 1. Unpack, mount/burn, install the game, use the keymaker from the \Razor1911 dir or any of the following keys: U6F7-WMAU-I1I5-V8X7-1911 NESJ-48XZ-I8S2-A3F4-1911 PS9H-H4RE-E7A5-Y8P6-1911 NPJS-CAKF-K5G5-W5U6-1911 QMRH-UJRE-U0N7-R2Q5-1911 Step 2 Copy the crack from the \Razor1911 dir into your installation directory. Step 3 Unpack Default_profile.zip into %USERPROFILE%\My Documents\Battlefield 2142\. Then open %USERPROFILE%\My Documents\Battlefield 2142\Profiles\0001\Profile.con with a text editor and change its content to your likings. The following fields might be of interest: //name of the in-game user: LocalProfile.setName "Razor1911" //login username: LocalProfile.setEAOnlineMasterAccount "Razor1911" You might also want to have a look at the other files in this dir! Step 4 Start the game, when prompted by the login prompt, enter whatever you used for LocalProfile.setEAOnlineMasterAccount. If you didn't change anything in Profile.con this will be "Razor1911". You will be prompted by a box telling you are playing in offline mode, press 'OK'. Now select your profile and the game will start! P.S. If you want to play on any official servers, buy the game! Razor 1911 Greetings ~~~~~~~~~~~~~~~~~~~~ To the honorable competition. /\ Razor 1911 /__\ Since 1985 /\ /\ /__\/__\ SUPPORT THE COMPANIES THAT PRODUCE QUALITY SOFTWARE! IF YOU ENJOYED THIS PRODUCT, BUY IT! SOFTWARE AUTHORS DESERVE SUPPORT!! Link to comment Share on other sites More sharing options...
nissan350zpimp Posted November 12, 2006 Author Share Posted November 12, 2006 ok 1. how do i unpack 2.this is how the files look like when it finshed downloading. 3. how do i fix the first .001 file i made it .rar and the rest are how they came. 4. on 3. i made another folder with the same files incase i mess up. heres the website link with the image i try to upload it here and it says THE FOLLOWING ERROR(S) WERE FOUND The total filespace required to upload all the attached files is greater than your per post or global limit. Please reduce the number of attachments or the size of the attachments. http://i15.tinypic.com/4dqlj6b.jpg Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted November 12, 2006 Share Posted November 12, 2006 open your folder, click on "tools" then "folder options" then the "view" tab then uncheck the box for "hide file extensions for known file types" This will make your life alot easier. Now you can remove the .rar that you added to the file name, so it will be back the way it was. Then open winrar, and click on "file" then "open archive" then browse to the first file. If you cannnot view that file type, go down to "file types" and change it to "all file types" then select the first, and all should open. :) ps. concerning the info for installing this game in the file.nfo. If you are going to have trouble following these instructions, then you really shouldn't be pirating software, as it is not a simple install and play process, and your getting about as much help as your going to get in this forum already Link to comment Share on other sites More sharing options...
nissan350zpimp Posted November 12, 2006 Author Share Posted November 12, 2006 well i know how to expet like this. i downloadeed nfsu1+2+ most wanted. and it cleary said wat to do. i'll try this. Link to comment Share on other sites More sharing options...
nissan350zpimp Posted November 12, 2006 Author Share Posted November 12, 2006 ok nice. i'm installing it thank you for your help Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted November 12, 2006 Share Posted November 12, 2006 glad we were able to help :) Link to comment Share on other sites More sharing options...
