Kerzhi Posted November 7, 2006 Share Posted November 7, 2006 Recently, I am unable to download anything, unfortunely I don't have a clue what the problem is, help would be much appreciated. I have downloaded both Firefox 2.0 and IE 7, but after reading other posts, this probably isn't the problem. I have also checked my firewall and allowed in & out access for bitcomet, I am also running Windows XP. Thank You. Link to comment Share on other sites More sharing options...
kluelos Posted November 8, 2006 Share Posted November 8, 2006 Check the trackers tab and look at the result you're getting from the tracker. Link to comment Share on other sites More sharing options...
Kerzhi Posted November 8, 2006 Author Share Posted November 8, 2006 erm...where can I find this? Thanks Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted November 8, 2006 Share Posted November 8, 2006 below "summary" above "files" Link to comment Share on other sites More sharing options...
Kerzhi Posted November 9, 2006 Author Share Posted November 9, 2006 This is going to sound stupid...but where is that? Could you direct me click by click where to go please. Thanks Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted November 9, 2006 Share Posted November 9, 2006 above the "paypal" logo its plainly there in your screenshot, I can't imagine how you could not see it Link to comment Share on other sites More sharing options...
Kerzhi Posted November 9, 2006 Author Share Posted November 9, 2006 Thanks, Yeah it is quite obvious...:P It seems I can't connect to the tracker, is any more help possible? Link to comment Share on other sites More sharing options...
juniorlau Posted November 9, 2006 Share Posted November 9, 2006 Check the trackers tab and look at the result you're getting from the tracker. I have the same problem like you, and I am using 0.70 as well, it works before, but suddenly not working, I search the whole forum for answer, but no luck. Want to see someone can help here.... I am using Window Firewall, and Spydoctor for the firewall, I have install Firefox too. By the way, I cannot do screen shot in the message box either, can you please let me know how....Thanks. Link to comment Share on other sites More sharing options...
cassie Posted November 10, 2006 Share Posted November 10, 2006 By the way, I cannot do screen shot in the message box either, can you please let me know how....Thanks. Read through here: http://forums.bitcomet.com/index.php?showtopic=3881 cassie :) Link to comment Share on other sites More sharing options...
rocket9244 Posted November 10, 2006 Share Posted November 10, 2006 i cant see my downloads..its showing im downloading 2 files in the statisticts pane Overall Infos: Torrents: 2 | Peers: 867 | Sockets: 1858 (HTTP: 8) TCP Connections: Established: 798 | Half-Open: 4 | Waiting: 101 Overall Download Rate: 155 KB/s Connection Limits: 40 - 800 per task Overall Upload Rate: 3 KB/s Upload slots: 1 /- .but summery pane isn't showing anything ie: downloads.name/size/%/kb down/kb up/time left/seeders/health/..none of these things..just a blank page.how do i correct this. Link to comment Share on other sites More sharing options...
rocket9244 Posted November 10, 2006 Share Posted November 10, 2006 how do i take a screen shot.to show you what it looks like ? Link to comment Share on other sites More sharing options...
rocket9244 Posted November 10, 2006 Share Posted November 10, 2006 how do i take a screen shot.to show you what it looks like ? ok i got screen shots..heres what i mean. Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted November 10, 2006 Share Posted November 10, 2006 Rocket, it seems by your report that your files are downloading fine, and at a pretty good rate too. If you don't understand how the process works, then please review the guide "new to bit torrent" by soraiya. this guide will give you all the basics so you are better prepared to ask any questions you may have. Kerzhi, I suggest you download a known good torrent. this will tell us if the problem is with your client, or with the torrent you are using. here is a good source... http://distribution.openoffice.org/p2p/index.html You should also get good speed with one of these. Suspect Link to comment Share on other sites More sharing options...
Kerzhi Posted November 10, 2006 Author Share Posted November 10, 2006 Thanks, unfortunaley it still doesn't work. Link to comment Share on other sites More sharing options...
bitdave Posted November 10, 2006 Share Posted November 10, 2006 Kerzhi, who do you get your internet connection from? (who is your ISP???) Link to comment Share on other sites More sharing options...
Kerzhi Posted November 10, 2006 Author Share Posted November 10, 2006 Ukonline, but previously there had been good connections, and only since last week, bitcomet hasnt worked, I have been with Ukonline for a good couple of months now. Link to comment Share on other sites More sharing options...
bitdave Posted November 10, 2006 Share Posted November 10, 2006 I think the problem is with your ISP. Read Here Link to comment Share on other sites More sharing options...
Kerzhi Posted November 10, 2006 Author Share Posted November 10, 2006 Damn...so theres nothing you or I can do, besides change my ISP. Link to comment Share on other sites More sharing options...
juniorlau Posted November 10, 2006 Share Posted November 10, 2006 Damn...so theres nothing you or I can do, besides change my ISP. I have a Yahoo DSL as my ISP, WIndow firewall, and Spyware doctor, Window XP, as I mention before, Ican not download anything. Is Yahoo DSL has problem too?? Link to comment Share on other sites More sharing options...
rocket9244 Posted November 10, 2006 Share Posted November 10, 2006 i cant see my downloads..its showing im downloading 2 files in the statisticts pane Overall Infos: Torrents: 2 | Peers: 867 | Sockets: 1858 (HTTP: 8) TCP Connections: Established: 798 | Half-Open: 4 | Waiting: 101 Overall Download Rate: 155 KB/s Connection Limits: 40 - 800 per task Overall Upload Rate: 3 KB/s Upload slots: 1 /- .but summery pane isn't showing anything ie: downloads.name/size/%/kb down/kb up/time left/seeders/health/..none of these things..just a blank page.how do i correct this. i guess it was a fluke.now i can see everything.. to do a screenshot..get a page you want.press the printscreen button..open paint .click edit,then paste.thats it. Link to comment Share on other sites More sharing options...
yabos500 Posted November 11, 2006 Share Posted November 11, 2006 hi..need someone's opinion/advice...i cant seem to download files from sportbit.org..it's forever saying "Connecting" and it says Tacker Reture Zero Length Response..what does that mean? Link to comment Share on other sites More sharing options...
Kerzhi Posted November 12, 2006 Author Share Posted November 12, 2006 Damn...so theres nothing you or I can do, besides change my ISP. Link to comment Share on other sites More sharing options...
bitdave Posted November 12, 2006 Share Posted November 12, 2006 You can try using a proxy for your tracker connections. http://www.proxy4free.com/index.html If you choose to use a proxy only use it for the tracker connections also you should check the option in Bitcomets preferences to Report LAN ip to tracker Also in Bitcomets preferences change the Encryption option to Always Enable Besides using a proxy for tracker connections and using encryption for all peer connections there isnt much you can easily do. Link to comment Share on other sites More sharing options...
Kerzhi Posted November 13, 2006 Author Share Posted November 13, 2006 Thanks for your help. I have downloaded ''ProxyWay''. But how do I use it, Thank You. Link to comment Share on other sites More sharing options...
Dark_Shroud Posted November 14, 2006 Share Posted November 14, 2006 I have a Yahoo DSL as my ISP. They're AT&T Yahoo DSL now. They limit the speed you can upload at, but that's about it. Link to comment Share on other sites More sharing options...
