crack codes
pitstop66
I downloaded this, but quite a long time ago so it probably isnt from the same source.
If the crack you are talking about is an .exe file, its probably a case of installing the software then going into its directory and replacing the exe file there with the cracked version.
Most downloads have a readme.txt that tell you exactly what needs to be done, so your best bet is starting there.
Guest
