pepsi80 Posted November 13, 2006 Share Posted November 13, 2006 Hi there... I really need helps.... I have tried the instructions from portforward.com to set up my router modem. I am currently using Aztech 600EW with wireless. I have set the listening port, but some how when I download in bitcomet, the peers tab ony have "Local" and "NAT Trav...". And I have tried to go to canyouseeme.org to check my port, well, the result is: Error: I could not see your service on 124.82.20.151 on port (10044) Reason: Connection timed out Can anyone please tell me why is this happening? And I exactly can I set my port forward to be opened? Thank you very much for your help! Waiting for your answers.... Pepsi80 Link to comment Share on other sites More sharing options...
petch01 Posted November 13, 2006 Share Posted November 13, 2006 Your modem/router has a build-in firewall with some good security features such as. NAT for basic Firewall support Packet Filtering Firewall Support Stateful Packet Inspection Support Protection against Denial of Service attacks These features can be responsible for blocking incoming connections. Read you modem/router manual carefully to find out about the functions of the settings and play a little around with it. I think the answer lies in your modem/router firewall. Petch01 Link to comment Share on other sites More sharing options...
pepsi80 Posted November 13, 2006 Author Share Posted November 13, 2006 Oh, thank you very much, Petch01.... I'm going to try that out.... If I figure anything out, will update you. Thank you for your help!!! pepsi80 Link to comment Share on other sites More sharing options...
pepsi80 Posted November 13, 2006 Author Share Posted November 13, 2006 haha... great news!!! Finally my port forward port is opened now!!!! Guess what.... the portforward.com has missed out another thing which is needed to be opened, which is the "Access Control" under "Security", we need to set the BitCom1 to Applied Rules as well.... Just exactly the same thing when we do the Port Forwarding's Applied Rules. Thank you very much!!! pepsi80 Link to comment Share on other sites More sharing options...
Dark_Shroud Posted November 14, 2006 Share Posted November 14, 2006 NAT for basic Firewall support NAT (Network Address Trasnlation) isn't a firewall. But it is good to have. Link to comment Share on other sites More sharing options...
madness_hero Posted December 4, 2006 Share Posted December 4, 2006 need some help here. I'm using a TL-R402M here and I followed everything on portforwarding.com but in the end when i check with http://canyouseeme.org/, got a : Error: I could not see your service on 203.121.47.20 on port (15305) Reason: Connection timed out and indeed when I check with the PEERS tab, I got only NAT TRANSVERSAL, meaning non of my ports are forwarded. but here's the funny thing, I've set my internal IP address to 192.168.1.101 but it shows that my IP is 203.121.47.20 and that isn't even my external IP address. can someone help me please........... Link to comment Share on other sites More sharing options...
kluelos Posted December 4, 2006 Share Posted December 4, 2006 It's your router's WAN IP address, which it was assigned by your ISP. The rest of the world can't see your computer, it can only see your router. It doesn't know what's behind the router, or care. It's the router's job to take that incoming request and forward, or "route" it to the proper computer connected to its LAN side-- that would be your computer, with its LAN IP address, valid and of interest only inside the LAN. Link to comment Share on other sites More sharing options...
madness_hero Posted December 4, 2006 Share Posted December 4, 2006 meaning it doesn't have anything to do with the port forrwarding, right? but still, I don't know what went wrong when I try to port forward............ Link to comment Share on other sites More sharing options...
kluelos Posted December 5, 2006 Share Posted December 5, 2006 Check your router's port-forwarding (virtual server) setup again. Make sure it's forwarding your BC listen port, to your computer's static LAN IP, for both TCP and UDP protocols. Then check (with IPCONFIG) to make sure your computer's static LAN IP is what you think it is, namely 192.168.1.101. If it's not, go back into your network connection properties and set up your static IP again. Make sure you've got it right. Reboot, check IPCONFIG again, and make sure it's right. Link to comment Share on other sites More sharing options...
madness_hero Posted December 5, 2006 Share Posted December 5, 2006 Check your router's port-forwarding (virtual server) setup again. Make sure it's forwarding your BC listen port, to your computer's static LAN IP, for both TCP and UDP protocols. Then check (with IPCONFIG) to make sure your computer's static LAN IP is what you think it is, namely 192.168.1.101. If it's not, go back into your network connection properties and set up your static IP again. Make sure you've got it right. Reboot, check IPCONFIG again, and make sure it's right. yeah, did that. I pick ALL for Protocol, so it's UDP and TCP enabled, but still http://canyouseeme.org/ gives a negative sign could it be the router's WAN IP Address that's being the problem? I've attached a pic of the VIRTUAL SERVER settings and the BC setting, and as you can see the speed is like h*** and all of the connections are local Link to comment Share on other sites More sharing options...
kluelos Posted December 5, 2006 Share Posted December 5, 2006 There are a couple of possibilities First, you are behind a router/firewall that you don't control, upstream of you. That often happens if you're connected through an apartment or dormitory or business which provides internet service. In that case there's not much you can do. Second, you have a software firewall blocking the port. It's up to you to be aware of what's running on your computer, and it's entirely possible to have a firewall and not know it. Many security suites install firewalls without being all that definite about telling you so. Temporarily connect the computer directly to the modem, bypassing the router. (Remember that you'll need to change your network configuration to comply with your ISP's requirements, to do this.) Then try again. If you get remote connections now, then the problem was your router and you didn't get the port forwarded correctly. If you still can't get remote connections, then you've either still got a firewall blocking the port, or you are behind someone else's firewall and it will not ever work. Link to comment Share on other sites More sharing options...
rbarhat Posted September 26, 2007 Share Posted September 26, 2007 haha... great news!!!Finally my port forward port is opened now!!!! Guess what.... the portforward.com has missed out another thing which is needed to be opened, which is the "Access Control" under "Security", we need to set the BitCom1 to Applied Rules as well.... Just exactly the same thing when we do the Port Forwarding's Applied Rules. Thank you very much!!! pepsi80 Hey man, what changes did u make in access control.. Plz let me know, i might also be able to forward that way... Link to comment Share on other sites More sharing options...
kluelos Posted September 26, 2007 Share Posted September 26, 2007 Posting into a thread that's been dead since last December isn't too smart. Very likely the person who posted the thing isn't reading the forum anymore. And it's pretty poor technique. Search for solutions among the old threads, but if you can't find one, start your own new thread rather than necropost into a long-dead one. Link to comment Share on other sites More sharing options...
