nashy666 Posted November 15, 2006 Share Posted November 15, 2006 :D HELLO HOPE YOU CAN UDERSTAND WHAT IAM ON WITH,WHEN I SEARCH FOR ITEMS IN SEARCH MODE ALL THE INTERNET SITES SHOW UP HOE DO I GET RID OF THAT HISTORY WITHOUT CLICKING AND DELEETING EVERY SINGLE FILE THANKS FOR ANY SUGGESTIONS :) Link to comment Share on other sites More sharing options...
Dark_Shroud Posted November 17, 2006 Share Posted November 17, 2006 I deleted your other thread. Do not post in all caps again as it is very rude. Now try this program for cleaning your computer and various history files. http://www.ccleaner.com Now for a registry cleaner: http://www.majorgeeks.com/download.php?det=2048 Link to comment Share on other sites More sharing options...
nashy666 Posted November 17, 2006 Author Share Posted November 17, 2006 :rolleyes: Thanks for the info and and yes i shouldnt use caps locks thanks again :D Link to comment Share on other sites More sharing options...
Meverick Posted November 18, 2006 Share Posted November 18, 2006 I would just like to add that I and others I know have used ccleaner and it screwed our systems up.It deleted some essential files making me need to do a system restore. I find Registry Mechanic v-good. Link to comment Share on other sites More sharing options...
Dark_Shroud Posted November 18, 2006 Share Posted November 18, 2006 CCleaner is free and does a good job. I'm not trying to be mean or rude but its not the program's fault that you used it to deleted some important files. This is why you need to pay attention to your settings. I accidently messed up IE7 beta 3 using CCleaner. But that was my own fault and I admit that. Lucky for me IE7 RC-1 and IE7 Final both can fix and did fix the problem I made. Link to comment Share on other sites More sharing options...
Meverick Posted November 24, 2006 Share Posted November 24, 2006 I understand that it's down to me which files to delete but if like me your not that savvy it would be nice to rely on the program to choose the action necessary. Link to comment Share on other sites More sharing options...
