some things wont work
I'm_Lost
With what little info you posted, there is nothing we can do to help you.
I suggest you do some reading in the forum and here...
http://en.wikipedia.org/wiki/Bittorrent
After you have learned a bit about how bit torrent works, it is likely you will have your answer, or at least know what question to ask.
ps. if some/most of your torrents are working, then its not likely a bit comet problem.
