ftw_drew_ytr Posted November 18, 2006 Share Posted November 18, 2006 :mellow: just wondering when download is complete ....... how do you go about actually playing the torrent ? as the preview doesn't work and also would anyone care to answer this question ..... after download is complete ... do you have to let the torrent upload aswell and if so then how long for Link to comment Share on other sites More sharing options...
dawin45 Posted November 18, 2006 Share Posted November 18, 2006 if a torrent is a movie and the bittcomet previwer doesn't work you could use vlc media player...(that's the best one there is)... or if you downloaded the torrent you could "open it" by pressing open dir after you selected the torrent... after download you have to let him upload as well till you reach 1.1 ratio in bittcomet that part is called U/D ratio.. Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted November 18, 2006 Share Posted November 18, 2006 If you have problems using the files you downloaded, the please include a complete file list (with extensions) of what you downloaded. Adding a link to where you downloaded the torrent would be a good idea too. Also, this wouldn't be a bit comet question, so please post that question in the proper area. Suspect Link to comment Share on other sites More sharing options...
cassie Posted November 18, 2006 Share Posted November 18, 2006 Please do not duplicate posts. You just asked the same questions here: http://forums.bitcomet.com/index.php?showtopic=4611&hl= ... and less than one hour later, you ask again. cassie Link to comment Share on other sites More sharing options...
