Iamart Posted November 21, 2006 Share Posted November 21, 2006 For some reasson when i have the program running for like 5 or 10 min . the comp reboot it self . Did this happened to anyone ? Link to comment Share on other sites More sharing options...
cassie Posted November 21, 2006 Share Posted November 21, 2006 Hi, Which version of 'the program'? While we're at it, why don't you look at my sig and provide at least some more information? It'll probably help... cassie :) Link to comment Share on other sites More sharing options...
Iamart Posted November 22, 2006 Author Share Posted November 22, 2006 Hola Well the version is the last one , 0.77 , my S.O. is windows xp home edition and i have a cable modem Webstar from ONO , no firewall and i have Avast antivirus but isnt running allways. Thx ;) Link to comment Share on other sites More sharing options...
StarDancer Posted November 22, 2006 Share Posted November 22, 2006 Iamart said: Hola Well the version is the last one , 0.77 , my S.O. is windows xp home edition and i have a cable modem Webstar from ONO , no firewall and i have Avast antivirus but isnt running allways. Thx ;) ok am not a techie but i will give you the same advice i have seen them give countless others try uninstalling the 0.77 version and going with the 0.70 version as it is the latest STABLE release and that may help you... you can get the 0.70 version from www.bitcomet.com.. hope that helps :) Link to comment Share on other sites More sharing options...
Iamart Posted November 22, 2006 Author Share Posted November 22, 2006 Thx , will try that Link to comment Share on other sites More sharing options...
cassie Posted November 23, 2006 Share Posted November 23, 2006 Just to add a bit: you should never connect to Internet without a firewall. If you don't have one, you should at least use the firewall that is included with your Windows XP. Also, you should scan your system very carefully for viruses, trojans, adware and spyware. You should use your antivirus program but should also get and use Ad-Aware and SpyBot S&D, to find things that your antivirus can't. cassie :) Link to comment Share on other sites More sharing options...
