eazyrog Posted November 27, 2006 Share Posted November 27, 2006 Hi all, Cabn some one please please help me out. I have NTL 10bm at home via a NTL supplied silver cable modem. I need to buy a Wireless Router. I have seen the sticky about what not to buy but i cant find any suggestions. Can you guys please recemmend a top end wireless router that i can use with least problems. Thanks Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted November 27, 2006 Share Posted November 27, 2006 I like my dlink routers. I have two of them, and they are very easy to setup, and have very few problems. However, I don't us NTL, and since I believe they put all users behind a proxy, there might be some issues I'm not aware of. I recommending getting advice from someone that uses your service. Suspect ps. Perhaps our support team might have some thoughts regarding this. Link to comment Share on other sites More sharing options...
kluelos Posted November 28, 2006 Share Posted November 28, 2006 The main reason for lack of recommendations is that most routers, and most brands of routers, are perfectly good. Indeed, most of the routers being recommended against, are also perfectly good for almost everything except P2P. But some of them try to help you by "remembering" recent connections. That will speed up general internet usage, and is a good idea overall. But they do have problems trying to remember too many connections, and since P2P can create several hundred connections in under an hour, it becomes a matter of whether this memorization interferes with making all those connections. Link to comment Share on other sites More sharing options...
