Newbie Alert Need Peer Help Urgently!!
Hi There!!
I'am use a slow dial up connection of 33.2 kbps, i have done all the settings im connectiong to remote peers (max 4) as well.
but i can only download from the local peer (1-3 kbps) and i cant download anything from the remote peers ( 0 kbps, all along, although they are connected). im new at this and need help, any additional info will be highly appreciated.
e-mail: rattlesnake_max101@yahoo.com
Each peer in a swarm makes the best connections it can to the other peers. Unfortunately, your slow connection speed makes you a pretty undesirable connection, so most of them will opt to connect to somebody faster. That's not anyone's particular choice to do, it's how bittorrent clients work.
