george40 Posted June 19, 2006 Share Posted June 19, 2006 (deleted) Link to comment Share on other sites More sharing options...
bitdave Posted June 19, 2006 Share Posted June 19, 2006 I dont understand what your question is, please clarify. You can disable UPnP port mapping in Bitcomet. (uncheck the option "UPnP port mapping" and the option "Remove port on NAT/firewall") You can disable UPnP service in Windows if you dont want to use UPnP at all. (Start -> Run -> services.msc) stop and disable SSDP and UPnP Device Host You can disable UPnP in your router. (different for each router) Link to comment Share on other sites More sharing options...
george40 Posted June 20, 2006 Author Share Posted June 20, 2006 ^ Thats exactly what I needed. Thanks. Link to comment Share on other sites More sharing options...
