chevys10 Posted December 3, 2006 Share Posted December 3, 2006 I am trying to uninstall bitcomet and it wont let me do it. I've deleted the active downloads and even went into the program files and tried deleting it one by one and it still won't. I need to uninstall to reinstall it HELP!! Link to comment Share on other sites More sharing options...
ekw Posted December 3, 2006 Share Posted December 3, 2006 Maybe theres a process of bitcomet running. Make sure u close bitcomet and try again. And to double check if its closed, do a CTRL+ALT+DELETE and make sure a bitcomet.exe isn't running. Link to comment Share on other sites More sharing options...
kluelos Posted December 3, 2006 Share Posted December 3, 2006 When you say that "it won't let you do it", what exactly are you doing and what exactly happens when you do? Link to comment Share on other sites More sharing options...
